Введение
There has been some worm under the outer shell but over the display, and so I disassembled it to clean it
Выберете то, что вам нужно
Make sure the machine is not under power and
remove the inner container
Remove the screw on the left side of the hinge of the lid (whith a philips 1 screwdrive)
After the screw is removed, you can move the lid (in open position) to the other side and slide it off the hinge (removing the lid completely)
Turn the complete machine upside down
Remove the four (PH1) screws from the four rubber stands.
When all screws are removed from the bottom side, the metal cover can be simply lifted up, and the motor is visible
Turn the device back upwards
Remove the six (PH1) screws around the grey part (beneath the removed lid)
Try moving the metal chassis downward, holding the grey inner part, creating a tiny gap on the left side of the machine and loosening the inner part a bit
Push the metal chassis inwards, so that the plastic hook is moved out of the metal chassis
After the front hook is moved out, the plastic display part can be turned to the right along the shorter side
Remove the (PH1) screw from the bottom part (upper side after turning out) of the display
Tilt the display brick and move it towards yourself to release the hooks on the upper side of the brick
Finally, the inner display and buttons can be reached and cleaned
Еще один человек закончил это руководство.
