Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Is your shaver not working even when its batteries have been replaced? if so, here is the guide to fix the problem by replacing the motor. All you need is a standard Phillips Screwdriver to remove two screws during the replacement.
Выберете то, что вам нужно
Pull the outer casing with one hand while holding the inner battery casing with the other hand.
