Введение
You have tried everything to attempt to make your device work again, if nothing has succeeded the motor may need to be replaced. Follow this guide on how to remove the motor.
Выберете то, что вам нужно
Remove the back battery cap from the device by twisting it to the unlock position and pulling.
Use a metal spudger to pry apart the silver plastic case.
Pull each side of the plastic case off.
Remove the rubber stopper from the top of the motor shaft by gently pulling it off.
6 участников успешно повторили данное руководство.
Один комментарий
My motor working intermittently. Took apart per instruction (very detailed, thank you). Everything loos good on the internals. I think my problem is succumb build up on the negative spring where it makes contact on negative end of battery. I scrapped it a little with tip of knife, working some what better. Need to find small wire brush to get in there and give it a good cleaning. Thank you for your guide :)
