Введение
Is your blade not spinning when you turn on your device, even when you hear the motor run? Check out this guide to replace your motor shaft.
Выберете то, что вам нужно
Remove the back battery cap from the device by twisting it to the unlock position and pulling.
Use the metal prying tool to pry apart the silver plastic case .
Pull each side of the plastic case off.
Remove the rubber stopper from the top of the motor shaft by gently pulling it off.
2 Комментариев
Thank you, small parts where switch is could be shown as well. Would be very helpful.
Advise for putting things back together: remove plastic switch cover and put back only after full reassembly
