Введение
Removing several sides of the camcorder and several pieces inside it in order to reach and remove the shoe adapter.
Выберете то, что вам нужно
Unscrew the J1 screws on the left side of the camcorder.
Unscrew the marked screws on the bottom of the camcorder.
Unscrew the marked screws on the back of the camcorder.
Pull off the left side of the camcorder. You may have to use a little force but don't worry about breaking anything in the camcorder.
Unscrew the indicated screw on the right side of the camcorder.
Unscrew the indicated screw on the back of the camcorder.
Remove the top cover of the camcorder by lightly lifting up on the back end of the top and tugging away from the lens (don't be afraid to use force).
Unscrew the indicated screws and remove the piece they hold in place.
