Введение
If your Panasonic KX-TGA410C handset’s keypad is not working as intended, or worn out and the numbers are no longer visible, use this guide to replace the button pad.
Выберете то, что вам нужно
Take an opening tool or pick and slide it in between the back and front cover all the way around the phone, then pull the back case off.
Use a Phillips #00 screwdriver to remove one 6.4 mm screw from the top left corner of the phone.
