Введение
Use this guide to replace the keypad on your phone.
Выберете то, что вам нужно
On the back of the phone, remove battery cover.
Push down on the marked indentation and pull downwards.
Once battery is removed, use the Phillips #00 screwdriver to remove the two silver screws at the bottom left and right corners on the back of the phone.
Use the Phillips #00 screwdriver to remove the three screws holding the circuit-board in place.
Once the screws are out, remove the charging contacts beneath the two bottom corner screws.
2 участников успешно повторили данное руководство.
