Выберете то, что вам нужно
Locate the memory card and battery card latch on the bottom of the camera.
Slide the latch to the open position.
Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
Gently remove the back casing.
Start at the bottom and carefully pry towards the top to get this piece free.
Gently lift up the LCD screen.
Using a plastic prying tool, flip up the latch that holds the thin ribbon in place.
It should fall out on its own or with a gentle tug.
Gently tug the thicker ribbon to remove it from its housing.
Not sure i the author forgot to add this, but the black part of this connector is locking mechanism for the ribbon. Lifting it will help.
Carefully remove the upper assembly, which houses the buttons and the flash battery.
Pry bars back gently as shown.
Fingers can be used but tool is shown for clarity.
After, releasing all the components, gently remove the flash assembly from the casing.
Replace buttons.
Replace the "On/ Off" button with the prongs facing away from the flash.
2 участников успешно повторили данное руководство.
Один комментарий
Olá ! Sugiro ter cuidado com a carga do capacitor do flash, melhor descarrega-lo com auxílio de uma lâmpada ou resistor
para evitar um choque elétrico.
