Введение
Directions are given as if you were holding the camera to take a picture.
Запчасти
Никакие детали не требуются.
  1. Locate the memory card and battery card latch on the bottom of the camera.
    • Locate the memory card and battery card latch on the bottom of the camera.
    • Slide the latch to the open position.
  2. Open the battery latch, and slide the battery release lever to the right.
    • Open the battery latch, and slide the battery release lever to the right.
  3. Remove the battery from the camera.
    • Remove the battery from the camera.
  4. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. Using a size #00 Phillips screwdriver, remove the three 4.58 mm screws on the bottom of the camera.
    • Using a size #00 Phillips screwdriver, remove the three 4.58 mm screws on the bottom of the camera.
    • Use this screwdriver for all screws in the device.
  6. Remove the 3.15 mm screw on the left side of the camera.
    • Remove the 3.15 mm screw on the left side of the camera.
  7. Remove the left side casing. Remove the left side casing.
    • Remove the left side casing.
  8. Remove the two 3.15 mm screws on the right side of the camera.
    • Remove the two 3.15 mm screws on the right side of the camera.
  9. Remove the bottom right panel.
    • Remove the bottom right panel.
  10. Gently remove the back casing. Start at the bottom and carefully pry towards the top to get this piece free.
    • Gently remove the back casing.
    • Start at the bottom and carefully pry towards the top to get this piece free.
Заключение
Andrew
Участник с: 11.10.2010
381 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 9-22, Regan Fall 2010 Member of Cal Poly, Team 9-22, Regan Fall 2010
CPSU-REGAN-F10S9G22
4 членов
Автор 8 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 3
За всё время: 3,069
