Введение
This guide will show you how to remove the top cover of your camera so you can replace it.
Выберете то, что вам нужно
Push the small gray tab on the top right corner to the left. The battery will pop out slightly.
Keep your finger clear of the battery when it pops out.
Lift up the bottom back cover by prying the bottom edge with the spudger.
Gently lift up the back cover with your hand from the bottom to the top.
Lift the tabs on the ZIF connectors.
The ribbon cables should easily come out of the ZIF connectors.
Using the spudger, pry off the top cover by gliding the spudger along the entire edge between the top cover and the front cover.
