Введение
This guide will demonstrate how to install the USB Ports on your camera.
Выберете то, что вам нужно
Push the small gray tab on the top right corner to the left. The battery will pop out slightly.
Keep your finger clear of the battery when it pops out.
Lift up the bottom back cover by prying the bottom edge with the spudger.
Gently lift up the back cover with your hand from the bottom to the top.
Lift the tabs on the ZIF connectors.
The ribbon cables should easily come out of the ZIF connectors.
Using the spudger, pry off the top cover by gliding the spudger along the entire edge between the top cover and the front cover.
Remove the small screw in the hole towards the top of the camera(#00P, 5.4mm).
Use the spudger to lift up the back logic board.
Using your fingers, gently wiggle and pull off the back motherboard.
Use the spudger to lift the upper tab from the main housing.
Gently lift the lower tab from the main body by prying it with your finger.
Gently pull off the plastic motherboard housing sideways.
Gently lift the tabs on the ZIF connectors connecting the lens to the front motherboard.
