Введение
This guide will show you how to almost completely strip down your device. Because of this, it may take a fair bit of time if you have never done a disassembly before. If you are looking for a guide to access the lenses themselves, this guide will not show that. However, it is possible if you have the patience to disassemble the lens casing.
Выберете то, что вам нужно
Remove both of the 3 mm screws on the bottom of the camera connected to the side panel.
Remove the remaining 3 mm screw holding on the side panel and remove the panel entirely.
On the opposite side of the camera, remove the two 3 mm screws.
Remove the bottom side panel and place it with its respective 3 mm screw.
Remove the front panel (the panel around the lens casing) from the camera.
Remove the two ribbon cables connected to the back panel (the panel this the LCD screen) by lifting up on their respective tabs and gently pulling out the cord.
Remove the back panel from the camera.
Unscrew the silver 2mm screw from the protection panel.
Unscrew the three black 8mm screws from the protection panel.
Remove the protection panel entirely.
Insert the flat end of a spudger underneath the motherboard and twist. This will disconnect it from the rest of the device.
Using the pointed end of a spudger, flip up the two black tabs holding the ribbon cables in place.
Unscrew the three 3mm screws holding the photoreceptor in place.
Lift the photoreceptor and gently pull it to release the now disconnected ribbon cable.
Gently lift and remove the lens casing, pulling it free from the now disconnected ribbon cable.
