Panasonic Lumix DMC-FZ35 LCD Replacement
Выберете то, что вам нужно
  1. Panasonic Lumix DMC-FZ35 LCD Replacement, Clear compartment: шаг 1, изображение 1 из 1
    • Remove the battery and memory card from the unit.
  2. Panasonic Lumix DMC-FZ35 LCD Replacement, Remove side screws: шаг 2, изображение 1 из 2 Panasonic Lumix DMC-FZ35 LCD Replacement, Remove side screws: шаг 2, изображение 2 из 2
    • Remove 1 screw (0.4mm) from left side of unit
    • Remove 1 screw (0.4mm) from right side of unit near Strap bar.
    • Remove 1 screw (0.6mm) from right side of unit next to usb door
  3. Panasonic Lumix DMC-FZ35 LCD Replacement, Remove Screws from Bottom: шаг 3, изображение 1 из 1
    • Remove 3 Screws from bottom of unit
    • Remove 2 (0.6mm) screws next to door
    • Remove 1 (0.4mm) screw opposite of door
  4. Panasonic Lumix DMC-FZ35 LCD Replacement, Remove top screw: шаг 4, изображение 1 из 1
    • Raise the Pop-Up flash by pushing the flash button.
    • Remove the screw (0.6mm) from underneath the flash assembly.
  5. Panasonic Lumix DMC-FZ35 LCD Replacement, Accessing the flex cables: шаг 5, изображение 1 из 2 Panasonic Lumix DMC-FZ35 LCD Replacement, Accessing the flex cables: шаг 5, изображение 2 из 2
    • Please be careful. Do not lift the cover fully because it is still attached to the Main Board via flex cables.
    • Lift the cover slightly as shown in picture # 1
    • Tilt the back cover as shown in picture #2. Be careful because the flex cables are still attached.
  6. Panasonic Lumix DMC-FZ35 LCD Replacement, Release the Flex cables: шаг 6, изображение 1 из 3 Panasonic Lumix DMC-FZ35 LCD Replacement, Release the Flex cables: шаг 6, изображение 2 из 3 Panasonic Lumix DMC-FZ35 LCD Replacement, Release the Flex cables: шаг 6, изображение 3 из 3
    • Flip up LCD cable clamp with a spudger or other tool.
    • Flip up backlite cable clamp with a spudger or other tool
    • Removal of the mic wire is optional. My suggestion is to leave it attached. The mic can get damaged if you pull on the wire.
  7. Panasonic Lumix DMC-FZ35 LCD Replacement, Remove the mic: шаг 7, изображение 1 из 3 Panasonic Lumix DMC-FZ35 LCD Replacement, Remove the mic: шаг 7, изображение 2 из 3 Panasonic Lumix DMC-FZ35 LCD Replacement, Remove the mic: шаг 7, изображение 3 из 3
    • Remove the 2 screws (0.4mm) that are holding the mic assembly
    • Next step (shown in picture #2) remove the metal mic hold part.
    • Next step (shown in picture #3) use a spudger to pry off the mic. Careful not to damage the wiring.
  8. Panasonic Lumix DMC-FZ35 LCD Replacement, Remove the LCD: шаг 8, изображение 1 из 3 Panasonic Lumix DMC-FZ35 LCD Replacement, Remove the LCD: шаг 8, изображение 2 из 3 Panasonic Lumix DMC-FZ35 LCD Replacement, Remove the LCD: шаг 8, изображение 3 из 3
    • Release the hold clips that hold the LCD retainer in place.
    • Remove the LCD metal retainer plate as shown in picture #2
    • Remove the LCD as shown in picture # 3
  9. Panasonic Lumix DMC-FZ35 LCD Replacement, Swap out Old LCD: шаг 9, изображение 1 из 1
    • Swap out your old LCD with the new one.
    • If your backlite is ok you can buy only the LCD Display. But it is easier to purchase the LCD with the backlite attached. Replacement LCD Display VYQ5034
Заключение
Еще один человек закончил это руководство.
Sales Cameraparts4you
Участник с: 07/01/16
3 150 Репутация
Автор 20 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 11
За последние 30 дней: 28
За всё время: 1,468
