Введение
Replacing the LCD face requires removal of a few small screws on the outside of the device.
Выберете то, что вам нужно
Use J0 screwdriver to remove the two 3.2 mm screws from the outside of the assembly.
Use the J0 screwsdriver to remove the two 5.6 mm screws from the inside of the face near the swivel.
Rotate the face to more easily gain access to the screws.
Slide the wide plastic opening tool underneath the crack of the side of the face and separate the components.
Carefully remove the filament connections from the LCD backing by lifting the black lever up first on the connector, then pulling gently outward from the LCD backing with your fingers.
Replace the filament connections into the backing of the new LCD face to complete replacement..
Еще один человек закончил это руководство.
