Введение
Replacing the lens connection assembly requires partial removal of the front lens panel of the device, necessitating the removal of several small screws.
Выберете то, что вам нужно
Remove the four 5.4 mm J000 screws from the front lens mount.
Use your hands or the thin plastic opening tool to remove the external housing ring as well as the smaller internal ring underneath.
Use the Thin Plastic Opening Tool to release the black connection ring.
Let the ring fall forward to reveal its underside.
Remove the two 2.7mm J000 phillips screws from the mount ring which connect to the ribbon of filament connections.
2 участников успешно повторили данное руководство.
