Введение
The Main PCB is one of the most important parts of the Panasonic Lumix DMC-GX85; it cannot function properly without one. Replacing a faulty Main PCB is made easy here.
Выберете то, что вам нужно
Remove the plastic hot shoe cover by sliding it towards the rear of the camera.
Using a spudger, gently lift the forward end of the shoe spring to disengage its locking mechanism.
While holding the forward end of the shoe spring up, push from its lifted end to remove the shoe spring.
Turn the camera so the side with the jack cover is facing you.
Near the camera's top end, remove the 4.0mm black Phillips #0 screw on the bottom in this orientation.
Open the jack cover and remove the 4.0mm black Phillips #0 screw inside.
Flip the camera upside down so the bottom of the camera is facing you.
Remove the two center 2.5mm black Phillips #0 screws.
Remove the outer 4.5mm black Phillips #0 screw.
Turn the camera so the display screen is facing you.
Rotate the top of the screen away from the camera body to access and remove the 4.5mm black Phillips #0 screw.
Remove the rear camera cover by gently pulling from the top side.
Turn the camera so the lens is facing down with the rear cover pulled back.
Disconnect the ribbon cable from the camera by pulling up on the black locking tab with an iFixit opening tool.
Pull the ribbon cable from the connector. The rear cover is now completely detached from the camera.
Remove the three 3.5mm silver Phillips #0 screws mounting the main PCB to the camera frame.
Disconnect the eight ribbon cables from the main PCB by pulling up on the black locking tabs with an iFixit opening tool.
Pull the ribbon cables from the connectors.
4 участников успешно повторили данное руководство.
2 Комментариев
Where i can find this replacement ? DMC-GX85 Main PCB Replacement
