Введение
Use this guide to replace the flash on a Panasonic Lumix DMC-ZS25 camera.
Выберете то, что вам нужно
Using a small screwdriver, remove the four 3.4mm screws from the right and left sides of your Panasonic Lumix Camera.
Using a small screwdriver, remove the two 2.6mm screws located next to the battery, on the outer casing.
Using a small screwdriver, remove the two 4.2mm screws located on the corner of the inner cover, under the screen.
Using your hands or the opening tool, separate the device into two pieces, as shown.
Using the spudger, unlock the screen cables from the circuit board.
Lift up the black clip to release the cables.
Using the plastic opening tool, pull up on the edge of the circuit board until it clicks.
Remove the board.
Using a small screwdriver, remove the 3.7 mm screw near the green chip inside the camera, as shown. This will release the top of the camera.
Place the tip of the spudger at the edge of the top board, and work around three sides to loosen it.
Using the opening tool, lift up the top board. Now you will be able to safely remove the flash.
