Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the following eleven screws securing the covers to the ZS3
Eleven 3 mm Phillips screws
Use the flat end of a spudger to pry apart the back cover from the rest of the unit as shown.
Using your fingernail or a spudger, flip up the ZIF locking flap on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit.
Remove the two LCD board ribbon cables out of their sockets.
Use the flat end of the spudger to gently pry the buttons from the back panel.
Remove the buttons in three pieces, starting with the top left one, then moving to one next to it. Once this is finished remove the rest of the buttons.
