Введение
This guide will teach you step by step on how to take apart the camera and locate the broken or malfunctioning flash component.
Запчасти
Никакие детали не требуются.
  1. Remove the battery and the SD card
    • Remove the battery and the SD card
  2. Unscrew the two 1.0 mm screws on the bottom with a Phillips #000 screwdriver
    • Unscrew the two 1.0 mm screws on the bottom with a Phillips #000 screwdriver
    • Unscrew the two 1.0 mm screws to the left with a Phillips #000 screwdriver
    • Unscrew the two 1.0 mm screws to the right with a Phillips #000 screwdriver
    • Carefully separate the back of the camera from the main body
    • Do not apply excessive force. The LCD is connected by ribbon cables that can be easily damaged
    • Use the tip of the 2.0 mm flathead screwdriver to flip up the black tabs on the ribbon cables
    • Pull gently on the ribbon cables to unseat them
    • Unscrew the 1.0 mm screws to the left with Phillips #000 screwdriver
    • Unscrew the 1.0 mm screws to the right with Phillips #000 srewdriver
    • Unscrew the one bottom 1.0 mm screw with a Phillips #000 screwdriver
    • Carefully separate the front of the camera from the main body
    • Use the tip of the 1.5 mm flathead screwdriver to disengage the plastic tab
    • Carefully lift the selector switch away from the motherboard
    • Unscrew the three silver 1.0 mm screws with a Phillips #000 screwdriver
    • Use the tip of the 2.0 mm flathead to disengage the metal tab, then carefully lift the shield away from the motherboard
    • Insert the tip of the 2.0 mm flathead into the center hole of the tripod mount, and apply force in the direction facing away from the button
    • Carefully lift the tripod mount out of the camera body
    • Use the 2.0 mm flathead to flip up the brown tab on the motherboard and carefully unseat the ribbon cable
    • Insert the tip of the 2.0 mm flathead screwdriver into the hole on the daughter board, then apply upward force to remove the daughter board from the main case
    • Use the 2.0 mm flathead to flip up the two tabs on the motherboard and carefully unseat the ribbon cables
    • Use the Phlllips #000 screwdriver to remove the three silver 1.0 mm screws
    • Carefully lift the lens assembly out of the camera
    • Use the tip of the 2.0 mm flathead screwdriver to disengage the tab on the back of the camera
    • Use the tip of the 2.0 mm flathead screwdriver to disengage the two tabs on the front of the camera
    • Carefully lift the top assembly out of place
    • Use the 2.0 mm flathead screwdriver to disengage the two tabs
    • Carefully lift the flash assembly out of place
Заключение
Derrick Thompson
Участник с: 30.01.2018
1 035 Репутация
Автор 5 руководств
Команда
Baylor, Team S2-G5, Johnson Spring 2018 Member of Baylor, Team S2-G5, Johnson Spring 2018
BU-JOHNSON-S18S2G5
3 членов
Автор 5 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 48
