Введение
This guide will teach you step by step on how to replace broken or malfunctioning Panasonic Lumix DMC-ZS6 LCD screens.
Выберете то, что вам нужно
Unscrew the two bottom 1.0 mm screws with a Phillips #000 screwdriver.
Unscrew the two 1.0 mm screws to the left with a Phillips #000 screwdriver.
Unscrew the two 1.0 mm screws to the right with a Phillips #000 screwdriver.
Use the tip of the spudger to flip up the black tabs on the ribbon cables.
Pull gently on the ribbon cables to unseat them.
Use the tip of the spudger to flip up the metal tabs.
Lift the LCD panel out of place carefully.
