Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
The first step in the repair process for the Panasonic PV-GS9 is to remove the Battery from the Camcorder.
  1. While holding the Camcorder firmly, pull down on the battery removal tab located on the underside of the camcorder. While holding the Camcorder firmly, pull down on the battery removal tab located on the underside of the camcorder.
    • While holding the Camcorder firmly, pull down on the battery removal tab located on the underside of the camcorder.
  2. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Then, pull the battery down away from the camcorder. Pull out as it becomes free. Then, pull the battery down away from the camcorder. Pull out as it becomes free. Then, pull the battery down away from the camcorder. Pull out as it becomes free.
    • Then, pull the battery down away from the camcorder. Pull out as it becomes free.
Заключение
Trevor Johnson
Участник с: 18.04.2010
31 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 7-9, Maness Spring 2010 Участник Cal Poly, Team 7-9, Maness Spring 2010
CPSU-MANESS-S10S7G9
4 членов
Автор 8 руководств
Один комментарий
Dónde puedo encontrar esa batería acá en Chile ?
mmanriquezsazo - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 1,226
