Panasonic PV-GS9 Microphone Replacement
Выберете то, что вам нужно
  1. Panasonic PV-GS9 Microphone Replacement, Microphone Replacement: шаг 1, изображение 1 из 3 Panasonic PV-GS9 Microphone Replacement, Microphone Replacement: шаг 1, изображение 2 из 3 Panasonic PV-GS9 Microphone Replacement, Microphone Replacement: шаг 1, изображение 3 из 3
    • Locate the blue plastic tool opener, then remove both the round record/playback and record/power control knobs by prying it open from the camcorder.
  2. Panasonic PV-GS9 Microphone Replacement: шаг 2, изображение 1 из 2 Panasonic PV-GS9 Microphone Replacement: шаг 2, изображение 2 из 2
    • Open the tape compartment.
    • Then flip the camcorder and locate two 4.5mm screws that are horizontal from each other and about 2 inches apart using a #00 Phillips screwdriver.
  3. Panasonic PV-GS9 Microphone Replacement: шаг 3, изображение 1 из 3 Panasonic PV-GS9 Microphone Replacement: шаг 3, изображение 2 из 3 Panasonic PV-GS9 Microphone Replacement: шаг 3, изображение 3 из 3
    • Use the blue plastic opening tool to remove the gray trim piece by prying it from top of the camcorder.
    • Be gentle when removing the trim piece. The plastic parts are fragile and can break easily.
  4. Panasonic PV-GS9 Microphone Replacement: шаг 4, изображение 1 из 1
    • Rotate the camcorder so that the eye piece is facing you.
    • Remove the four black 4.5mm screws, sitting behind the battery.
    • Remove the 5th screw to the right of the battery dock.
    • Remove the battery by gently pulling away from the camcorder.
    • Be careful and place screws together so you don't lose any.
  5. Panasonic PV-GS9 Microphone Replacement: шаг 5, изображение 1 из 2 Panasonic PV-GS9 Microphone Replacement: шаг 5, изображение 2 из 2
    • Rotate the camcorder so that the tape compartment is facing you.
    • Remove the single 4.5mm black screw above the hook for the hand strap.
    • Undoing the strap on one end may help.
    • Rotate the camcorder so that the lens is facing you.
    • Remove the single 4.5mm black screw from the front panel.
  6. Panasonic PV-GS9 Microphone Replacement: шаг 6, изображение 1 из 2 Panasonic PV-GS9 Microphone Replacement: шаг 6, изображение 2 из 2
    • Rotate the camcorder so that the bottom is facing towards you.
    • Remove the single remaining 4.5mm black screw from the bottom.
    • Remove the four silver 4.5mm screws from the body.
  7. Panasonic PV-GS9 Microphone Replacement: шаг 7, изображение 1 из 1
    • Open the LCD screen on the side of the camcorder.
    • Using a #00 screwdriver, remove the two 4.5mm silver screws located on either side of the hinge of the LCD screen.
  8. Panasonic PV-GS9 Microphone Replacement: шаг 8, изображение 1 из 2 Panasonic PV-GS9 Microphone Replacement: шаг 8, изображение 2 из 2
    • Carefully remove the front cover from the body of the camcorder.
    • This should come apart with relative ease, however a plastic opening tool may help remove the panel.
    • There is a ribbon cable attached to the front panel and the camcorder body, DO NOT pull that off when you remove this panel.
  9. Panasonic PV-GS9 Microphone Replacement: шаг 9, изображение 1 из 2 Panasonic PV-GS9 Microphone Replacement: шаг 9, изображение 2 из 2
    • Using your fingers, carefully pull the ribbon cable away from the logic board.
  10. Panasonic PV-GS9 Microphone Replacement, Microphone: шаг 10, изображение 1 из 1
    • Using a #00 phillips screwdriver, remove the four 4mm screws holding the circuit board in place.
  11. Panasonic PV-GS9 Microphone Replacement: шаг 11, изображение 1 из 2 Panasonic PV-GS9 Microphone Replacement: шаг 11, изображение 2 из 2
    • Remove the circuit board containing the ribbon cable, microphone, and infared sensor.
Заключение
Joey Bradshaw
Участник с: 04/18/10
10 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 7-9, Maness Spring 2010 Участник Cal Poly, Team 7-9, Maness Spring 2010
CPSU-MANESS-S10S7G9
4 членов
Автор 15 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 9
За последние 30 дней: 13
За всё время: 1,522
