Panasonic Power Supply Board Power Board Replacement
Выберете то, что вам нужно
  1. Panasonic Power Supply Board Power Board Replacement, Disk Tray Cover: шаг 1, изображение 1 из 1
    • Eject the disk tray from the DVD player before removing power supply.
  2. Panasonic Power Supply Board Power Board Replacement: шаг 2, изображение 1 из 1
    • Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier disassembly of the player.
  3. Panasonic Power Supply Board Power Board Replacement, Outer Case: шаг 3, изображение 1 из 2 Panasonic Power Supply Board Power Board Replacement, Outer Case: шаг 3, изображение 2 из 2
    • Remove the three screws running along the back edge of case cover.
    • Remove the two screws from each side of the case cover.
  4. Panasonic Power Supply Board Power Board Replacement: шаг 4, изображение 1 из 1
    • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
  5. Panasonic Power Supply Board Power Board Replacement, Front Panel: шаг 5, изображение 1 из 2 Panasonic Power Supply Board Power Board Replacement, Front Panel: шаг 5, изображение 2 из 2
    • Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
  6. Panasonic Power Supply Board Power Board Replacement, Disk Drive: шаг 6, изображение 1 из 3 Panasonic Power Supply Board Power Board Replacement, Disk Drive: шаг 6, изображение 2 из 3 Panasonic Power Supply Board Power Board Replacement, Disk Drive: шаг 6, изображение 3 из 3
    • Locate the four screws securing the disk drive assembly. There are two on each side.
    • Use a narrow screwdriver to remove all four screws.
    • Remove the blue ribbon wire from its connector. When doing this, be cautious to not damage the connector.
  7. Panasonic Power Supply Board Power Board Replacement: шаг 7, изображение 1 из 1
    • Lift assembly by the front to pull metal bracket from the power board.
    • Pull up back end and lift drive out.
  8. Panasonic Power Supply Board Power Board Replacement: шаг 8, изображение 1 из 1
    • With the drive assembly separate from the player, hold as shown and pull the bracket edges away from the disk drive.
    • Lift bracket off and reserve for re-assembly.
  9. Panasonic Power Supply Board Power Board Replacement, Power Board: шаг 9, изображение 1 из 2 Panasonic Power Supply Board Power Board Replacement, Power Board: шаг 9, изображение 2 из 2
    • Remove 4 screws from the power board as shown.
    • Lift the power board straight up and out of the chassis.
Заключение
Еще один человек закончил это руководство.
Kevin
Участник с: 04/26/11
375 Репутация
Автор 8 руководств
Команда
Cal Poly, Team 18-20, Garner Spring 2011 Участник Cal Poly, Team 18-20, Garner Spring 2011
CPSU-GARNER-S11S18G20
4 членов
Автор 11 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 19
За всё время: 5,197
