Введение
In this guide, you will learn how to replace the cassette holder spring on this device. This is a small strip of copper that causes the cassette door to spring open when the 'eject' button is pressed. If it becomes bent, broken, or pushed out of position, it will prevent your cassette door from opening or playing cassettes.
Выберете то, что вам нужно
Remove the three screws from the back of the device body.
Remove both screws from the battery compartment.
Remove the back of the device.
Make sure the brass colored spring by the cassette door is in the correct position.
Remove the screw that holds the spring if broken.
Remove the spring from the device.
Replace the old spring with the new spring, making sure that it is installed in the correct position.
Insert the screw back into position, ensuring that it holds the spring.
2 участников успешно повторили данное руководство.
