Panasonic SC-PM31 Fuse Replacement
Выберете то, что вам нужно
  1. Panasonic SC-PM31 Fuse Replacement, Removing the side and back screws: шаг 1, изображение 1 из 3 Panasonic SC-PM31 Fuse Replacement, Removing the side and back screws: шаг 1, изображение 2 из 3 Panasonic SC-PM31 Fuse Replacement, Removing the side and back screws: шаг 1, изображение 3 из 3
    • Remove the five 9 mm #2 Phillips screws from the side panel nearest the power button.
    • Repeat the process for the opposite panel.
    • Remove the two 15 mm #2 Phillips screws from the back of the top panel.
    • Remove the middle 10mm #2 Phillips screw from the back of the top panel.
  2. Panasonic SC-PM31 Fuse Replacement, Removing the panels: шаг 2, изображение 1 из 2 Panasonic SC-PM31 Fuse Replacement, Removing the panels: шаг 2, изображение 2 из 2
    • If you do not have a plastic opening tool, you can open the system using your finger. However, if you choose to use your hands, make sure to wear gloves. The panel is very sharp.
    • Swing the back half of the panel slightly away from the unit. Then, starting at the top back corner, slide plastic opening tool through the created gap from back to front. The panel should pop off. Repeat the process on the opposite panel.
  3. Panasonic SC-PM31 Fuse Replacement, Removing the white ribbon wire: шаг 3, изображение 1 из 1
    • Looking in through the side nearest the power button, use your fingers to pull the white ribbon connection toward you, away from the rear circuit board.
    • The process will require the use of moderate force and can be eased by wiggling the ribbon during removal.
  4. Panasonic SC-PM31 Fuse Replacement, Removing the top panel: шаг 4, изображение 1 из 2 Panasonic SC-PM31 Fuse Replacement, Removing the top panel: шаг 4, изображение 2 из 2
    • Remove the top panel. You will need to slightly bend the plastic tab outwards, to undo the clasp that is attached to the top.
    • When reassembling the device, reattach the white ribbon wire (Step 3) before replacing the top panel.
  5. Panasonic SC-PM31 Fuse Replacement, Removing the back panel screws: шаг 5, изображение 1 из 1
    • Remove the eight 9.5 mm #2 Phillips screws attaching the back to the device.
    There are 11 screws, not 8. One is where the screwdriver is pointing, and there is one more on each bottom corner under the lip.
    Xyrtranna - Ответить
  6. Panasonic SC-PM31 Fuse Replacement, Removing the back panel: шаг 6, изображение 1 из 3 Panasonic SC-PM31 Fuse Replacement, Removing the back panel: шаг 6, изображение 2 из 3 Panasonic SC-PM31 Fuse Replacement, Removing the back panel: шаг 6, изображение 3 из 3
    • With a gentle tug, unplug the red and black cable from the tan circuit board.
    • Using both hands, unlock the plastic back panel from the metal clasps (located on the sides of the unit) by pulling the plastic away from the metal. Focus on undoing first one clasp, then the other.
    • Slide the back panel toward you and off of the unit.
  7. Panasonic SC-PM31 Fuse Replacement, Removing the fuse: шаг 7, изображение 1 из 2 Panasonic SC-PM31 Fuse Replacement, Removing the fuse: шаг 7, изображение 2 из 2
    • Looking over the top of the tan and green circuit board, locate the fuse.
    • Gently pull the fuse out of the metal claps.
Заключение
Еще один человек закончил это руководство.
Jessica Chao
Участник с: 09/29/14
626 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 13-7, Forte Fall 2014 Участник Cal Poly, Team 13-7, Forte Fall 2014
CPSU-FORTE-F14S13G7
5 членов
Автор 7 руководств
2 Комментариев
What symptoms did fuse failure exhibit?
Any information on stereo decoding and LCD display faults?
Chris Phillips - Ответить
Will this fix the dead LCD display? Thanks
samkok37 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 8
За последние 30 дней: 30
За всё время: 4,151
