Введение
The Panasonic SDR H-100 is a device that records video footage. This device is very useful for recording footage, but becomes useless when the device cannot be charged due to a faulty charging port. This guide will teach you how to replace the charging port on this device so that the device becomes functional. The charging port is where the charging cable is put into to charge the battery in the camcorder. Make sure the correct tools are used to ensure a successful replacement of the charging port.
Выберете то, что вам нужно
Remove the four 4-mm screws on the bottom of the camcorder.
Remove the three 6-mm screws on the hand-strap side of the camera.
Pull out the charging port (DC input terminal) cover and remove the 4-mm screw located next to the input terminal.
Flip out the LCD screen to expose the inner screws. Remove the two black 4-mm screws.
Using a firm hold on both sides of the camcorder, gently pull apart the casing under the hand strap.
Unscrew the two black 4 mm screws from metal casing around the motherboard.
Remove the black 4 mm screw from the back of the camcorder underneath where the battery would have been.
Pull the plastic cover on the back out and up slightly until the back feels like it’s free, then pull back on the plastic (The top cover piece and back will be detached).
Unscrew the four silver 4 mm screws underneath the outer plastic cover.
This gives you access to the bottom of the zoom lever.
Using tweezers, pull on the black piece that is connected to the underside of the zoom lever while also pushing the back piece at an angle.
Do not disconnect the red and black wires while you are doing this.
Replace with new zoom lever.
Gently pull on the red and black wires directly outwards so that these wires become detached.
Push in on the tab and lift the metal bracket. Remove the metal bracket from the back panel.
Pull up gently on the larger orange piece. Then, gently pull out the piece to release it from the plastic back panel. The charging port is now ready to be replaced.
