Введение
If you need to replace the HDD of your Panasonic SDR H-100, follow this guide. The HDD is where the memory is stored for the camcorder. Without this the videos and pictures that are taken cannot be saved.
Выберете то, что вам нужно
Remove the four 4-mm screws on the bottom of the camcorder.
Remove the three 6-mm screws on the hand-strap side of the camera.
Pull out the charging port (DC input terminal) cover and remove the 4-mm screw located next to the input terminal.
Flip out the LCD screen to expose the inner screws. Remove the two black 4-mm screws.
Using a firm hold on both sides of the camcorder, gently pull apart the casing under the hand strap.
Gently pull the black plastic hard drive case away from the body of the camera. This will expose the hard drive (HDD).
Еще один человек закончил это руководство.
