Введение
If your Panasonic SDR H-100 zoom lever is sticking, working inconsistently, or not working at all, then use this guide to replace the malfunctioning part.
The zoom function on the Panasonic SDR H-100 allows the user to move their point of view closer to or further from the subject.
Before beginning, make sure to completely power off your device and disconnect it from any external power sources.
Выберете то, что вам нужно
Remove the four 4-mm screws on the bottom of the camcorder.
Remove the three 6-mm screws on the hand-strap side of the camera.
Pull out the charging port (DC input terminal) cover and remove the 4-mm screw located next to the input terminal.
Flip out the LCD screen to expose the inner screws. Remove the two black 4-mm screws.
Using a firm hold on both sides of the camcorder, gently pull apart the casing under the hand strap.
Unscrew the two black 4 mm screws from metal casing around the motherboard.
Remove the black 4 mm screw from the back of the camcorder underneath where the battery would have been.
Pull the plastic cover on the back out and up slightly until the back feels like it’s free, then pull back on the plastic (The top cover piece and back will be detached).
Unscrew the four silver 4 mm screws underneath the outer plastic cover.
This gives you access to the bottom of the zoom lever.
Using tweezers, pull on the black piece that is connected to the underside of the zoom lever while also pushing the back piece at an angle.
Do not disconnect the red and black wires while you are doing this.
Replace with new zoom lever.
