Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
The purpose of this guide is to show how to properly remove and replace the heat sink.
Выберете то, что вам нужно
Begin by turning the laptop upside down with the handle towards you.
Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
Remove the panel and set it aside.
Use a Phillips size 0 screwdriver to remove these 8 small screws.
Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
Locate the heat sink on the underside of the back cover.
It is the U shaped metallic piece.
Remove the four screws with a Phillips size 1 screwdriver.
One on each of the ends
Two on the base of the U shape
Being careful not to lose the brackets at the ends of the heat sink, lift it up and out.
Еще один человек закончил это руководство.
