Введение
This guide will show you how to remove the keyboard from the main unit.
Выберете то, что вам нужно
Remove the four screws above the keyboard using a Phillips #0 screwdriver.
Pull cover plate out of place revealing the ribbon cable connections to the motherboard
Remove the ribbon cable farthest from you.
Push the white tab (as shown in the second photo) to release the ribbon cable.
Remove both ribbon cable by pulling 2 white tabs on either side of the cable to the right
3 участников успешно повторили данное руководство.
Один комментарий
When replacing the KB, don'f forget the double sided fiberglass tape. The regular CF-29 KB is a backbone of thin aluminum sheeting, Most likely when you "pop" off the KB, its likely to bend. When you install a bent KB, it bounces when you type. Bend it back and tape it down with new tape. With the CF-30, removing that KB is totally different. Its locked down by brackets, not taped. You need to slide it forward unlocking it before popping it off, otherwise your KB keys start breaking. Be soft and confident, because you bet one chance to do it correctly. Sponsored by Black Hawk Toughbooks.
