Введение
The purpose of this guide is to show how to properly remove the optical drive.
  1. Locate the bay door for the battery on the left side of the laptop.
    • Locate the bay door for the battery on the left side of the laptop.
  2. Slide the latch to the right and then down to unlock it. Pull out the battery.
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Flip the device upside down with the handle facing away from you.
    • Flip the device upside down with the handle facing away from you.
    • Open the optical drive bay by sliding its latch to the right.
    • Locate optical drive release mechanism on the bottom of the laptop.
  4. Slide the latch cover to the right.
    • Slide the latch cover to the right.
  5. Push the exposed switch to the left to eject the optical drive. Push the exposed switch to the left to eject the optical drive.
    • Push the exposed switch to the left to eject the optical drive.
Заключение
2 участников успешно повторили данное руководство.
Clint Kirsop
Участник с: 13.04.2010
82 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 27-93, Amido Spring 2010 Участник Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 членов
Автор 24 руководств
Один комментарий
What kind of USB enclosure would this fit in?
Terence Higgins - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 6,472
