Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Locate the bay door for the battery on the left side of the laptop.
Slide the latch to the right and then down to unlock it.
Pull out the battery.
Remove the four hinge screws from the back of the computer.
Open the laptop and remove the four indicated screws with a Phillips size 0 screwdriver.
Pry off the plastic strip which was previously held in place by the screws.
Remove the four hinge screws to allow the hinges to rotate up and move.
Remove 16 screws from the top of the closed laptop.
12 Phillips size 1 screws
2 Phillips size 0 screws
2 Torx size 6 screws (T6)
Gently break the adhesive seal between the front and rear display cases with a plastic opening tool.
Pull the top halve of the casing up revealing the inside of the screen
The top half of the case can be removed by sliding the tabs out from under the hinges.
This makes unplugging the screen wiring much easier
There are 4 wires that need to be unplugged to remove the screen.
For the first wire, peel back the silver cover tape to reveal the connection.
Remove the 3 strips of black tape as shown to reveal connections 2 and 3.
Pull the wiring for each away from the connections to remove.
Using a plastic opening tool, lift the screen as shown from the case and pull free.
5 участников успешно повторили данное руководство.
Один комментарий
This guide is good for replacing the LCD screen, but it is not complete for the touchscreen panel, which requires some more delicate and precise steps. I think the title of the guide needs to be changed.
Thanks
