Введение
This guide will show you how to gain access to and replace the track pad board in your Panasonic CF-29.
Выберете то, что вам нужно
Push and slide the latch up to open the hard drive door.
Pull out the hard drive.
Flip the device upside down with the handle facing away from you.
Open the optical drive bay by sliding its latch to the right.
Locate optical drive release mechanism on the bottom of the laptop.
Begin by turning the laptop upside down with the handle towards you.
Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
Remove the panel and set it aside.
Use a Phillips size 0 screwdriver to remove these 8 small screws.
Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
Locate the track pad chip near the handle.
Remove the upper right screw.
Use a pry bar to detach the white ribbon cable shown.
Push the brown tab to release the cable
Remove the screw that was previously concealed under the now removed ribbon cable.
Remove the last ribbon cable.
Pry up on the brown part to release the ribbon cable.
Еще один человек закончил это руководство.
