Введение
This guide will show you how to remove the wireless card from a Panasonic Toughbook CF-29
Инструменты
Запчасти
Детали не указаны.
Begin by turning the laptop upside down with the handle towards you.
Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
Remove the panel and set it aside.
Use a Phillips size 0 screwdriver to remove these 8 small screws.
Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
Remove the black and white wires attached to the wireless card by simply pulling up.
Using a pair of plastic opening tools, push the two metal tabs away from the card.
The wireless card should now easily disengage from the motherboard.
Pull the card horizontally away from you to remove it from its housing.
2 участников успешно повторили данное руководство.
