Выберете то, что вам нужно
Remove all three 5mm screws from the top of the camera using a Phillips #0 screwdriver.
Rotate the camera to show the bottom side of the camera.
Remove the four 5mm screws on the bottom side of the camera with a Phillips #0 driver.
Pry with a spudger to disconnect the top-front part of the camera from the main body.
Slide the top portion of the camera forward revealing more screws.
Flip the camera on the right side.
Gently pull the front part from the main body to expose the cables connecting them.
Use your plastic opening tool to disconnect the connection point safely.
Press the tab with plastic opening tool and then pull the ZIF connector to detach.
Flip the camera on the bottom side.
Remove one more 5mm screw that had been uncovered previously with a Phillips #0 screwdriver.
Go to the battery basement's side.
Use your Phillips #0 screwdriver to remove the two 5mm screws on the battery base of the camera.
Rotate the camera to the left side, where the side port is located.
Open the side port door.
Remove three 5mm screws inside the side ports using Phillips #0 screwdriver.
Take off the left side of the camera.
Rotate the camera to the battery side.
Gently pull the side of the camera apart with only your hands.
Disconnect the ribbon cable with your plastic opening tool, so that the left side of the camera can be removed.
Look to the left side of the camera you have removed.
Remove six 5mm screws with your Phillips #0 screwdriver.
Take off the metal piece.
Use your plastic opening tool to disconnect the ribbon cable. Press the tab with plastic opening tool and then pull the ZIF connector to detach.
Use a plastic spudger to apply a firm amount of pressure to pry the hinge from the rest of the camera body.
Go back to the back side.
Take off the small plastic piece.
Rotate the right side of the LCD counter clockwise.
