Введение
This guide demonstrates how to remove and replace a Pandigital Super Nova screen in order to preserve the function of the device.
Выберете то, что вам нужно
Remove the screw covers from each corner of the back side of the device.
Set aside.
Using a Philips screwdriver, remove all four .15 mm screws from each corner.
Set aside.
Use a metal pry tool to separate the camera and the small clip that holds it in place.
Use a pair of small tweezers to gently pull the camera connector out of the motherboard.
Use a screwdriver to remove the six .15 mm screws that hold the motherboard in place. Set aside.
Remove the eleven screws that hold the screen to the base. Eight are .15 mm and three are .11 mm.
Use tweezers to carefully remove the connector between the screen to the tablet.
Lift the motherboard out of the tablet.
Remove the second connector between the screen and the motherboard.
Pry the silver screen box from away from the device.
Open each of the four clips securing the screen box to open it.
2 участников успешно повторили данное руководство.
