Выберете то, что вам нужно
Turn phone over so that the back side is facing up.
Using a finger, apply moderate pressure to the top of the back cover while sliding the cover down and off.
Lift and remove the back cover from the phone.
Locate the battery: It is a silver, rectangular object.
Insert a fingernail into the indent just below the battery about 0.5 inches from the bottom of the phone.
Then, apply pressure to the battery, pushing up and away from the phone. It will come out easily.
The slots for the Micro SD and SIM cards are directly above the battery tray.
To insert a card, slide it face up into the slot. To remove a card, slide the card out from the slot.
Micro SD Card Slot - On the Left
SIM Card Slot - On the Right
3 участников успешно повторили данное руководство.
