Введение
Before replacing most other part on this device, the battery must be properly disconnected in order to continue on. This guide will teach you how to remove and replace the battery.
Once the battery is separated from the nose, push down on the connector and pull the battery away from the connector.
2 человек успешно провели ремонт по этому руководству.
