Введение
Bring back to life your Parrot FLYPAD with a brand new battery.
This guide will assist you to correctly dismantle the controller, so that you may easily replace the battery. To prevent any loss of screws, it is important to utilize a magnetic mat placed under the controller.
Выберете то, что вам нужно
Use a T6 screwdriver to remove the six screws from the back of the controller: four 0.9 mm screws and two 0.1 mm screws.
Separate the plastic cover from battery.
Avoid damaging the wires and gently remove the battery from the motherboard.
Gently attach the wire connection from the new battery to the motherboard. Avoid touching the motherboard directly.
Еще один человек закончил это руководство.
