Введение
This guide will show you how to replace buttons on the front of a Parrot Flypad if they have stopped working. Follow the instructions carefully to successfully replace the front buttons.
Выберете то, что вам нужно
Position the controller so the back is facing up.
Use a T6 screwdriver to remove the six screws on the back of the controller: four 0.9 mm screws and two 0.1 mm screws.
Remove the foam adhesive that connects the front plate to the motherboard
Use a Phillips #0 screwdriver to remove the two 0.7 mm screws.
Remove the motherboard from the front plate.
2 участников успешно повторили данное руководство.
