Parrot FLYPAD Joystick Replacement
Выберете то, что вам нужно
  1. Parrot FLYPAD Joystick Replacement, Joystick: шаг 1, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Magnetic Project Mat
    $19.95
    Купить
    • Total of 6 Screws are located in the back of the controller.
    • Four 0.9mm T6 screws
    • Two 0.1mm T6 screws
    • Flip the Flypad over.
    • Remove the six screws using a T6 screwdriver.
    • Use a Magnetic Mat to prevent loss of screws. Set aside.
  2. Parrot FLYPAD Joystick Replacement: шаг 2, изображение 1 из 1
    • Flip the Flypad over again and separate the front and back. Be sure to remove the foam adhesive that connects the front plate to the motherboard.
    • Be aware that the Buttons (L1,R1) may fall out. Remember to put them back in place during reassembly.
    • Use Ph0 tool to remove the screws holding the motherboard in place.
    • Gently remove the motherboard from the front plate.
    The FLYPAD’s that come with the FPV kit do not have the weights and the rumble motor. The sticks are also not removable.
    Heath - Ответить
  3. Parrot FLYPAD Joystick Replacement: шаг 3, изображение 1 из 2 Parrot FLYPAD Joystick Replacement: шаг 3, изображение 2 из 2
    • Pop the joysticks out by pulling gently.
    Please add the removal of the motherboard screws. Also I have 3 of these controllers. The oldest has PHILLIPS head screws. The newest has the T6 screws. Just FYI.
    Heath - Ответить
  4. Parrot FLYPAD Joystick Replacement: шаг 4, изображение 1 из 1
    • Unscrew and replace joystick caps for a more comfortable grip.
    The Flypad that comes with the FPV kit does not have removable joystick caps.
    Heath - Ответить
Заключение
HUY NGUYEN
Участник с: 04/10/17
376 Репутация
Автор 3 руководств
Команда
UW Tacoma, Team S3-G5, Liner Spring 2017 Участник UW Tacoma, Team S3-G5, Liner Spring 2017
UWT-LINER-S17S3G5
5 членов
Автор 3 руководств
2 Комментариев
Do you know where I can find replacement joystick caps like the one shown in Step 4, please?
cbeilstein - Ответить
Same question as above regarding joystick caps please
Alex - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 684
