Введение
This guide shows you the process of reinstalling a C-Clamp style Sternum Strap on a Patagonia backpack.
This particular Sternum Strap is called a "C-Clamp" because the cross section of the clips is shaped like a "C".
Locate a proper Sternum Strap replacement. Reach out to Patagonia if you need a replacement.
At the bottom of the Sternum Strap "Rail" there is a flap.
Pull this flap back to expose the bottom of the Rail.
Slide the C-Clamp Clip back onto the Rail.
Repeat the steps above on the other backpack strap.
Slide the Sternum Strap to your desired position.
Hit the trails with your newly attached Sternum Strap!
Еще один человек закончил это руководство.
