Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
You will be taking the wheel off of your bike, removing the tire from the wheel, and patching the hole.
Notes:
  • Make sure that the wheel is fully deflated throughout the process, except for finding the hole.
  • When applying the rubber cement to the hole the thinner the layer the better, for faster drying.
Инструменты
Запчасти
Детали не указаны.
  1. Press the valve core while applying pressure to the tire to deflate the tire.
    • Press the valve core while applying pressure to the tire to deflate the tire.
  2. Insert the flat part of a tire lever under the tire coping. Apply pressure to the other end of the lever to lift the tire up and out of the wheel. Slide the lever around the circumference of the wheel to completely remove the tire.
    • Insert the flat part of a tire lever under the tire coping. Apply pressure to the other end of the lever to lift the tire up and out of the wheel.
    • Slide the lever around the circumference of the wheel to completely remove the tire.
    • Alternatively, if you have multiple tire levers, see if you can clip the first lever to a spoke to keep it in place. Then insert the second lever a few inches away. Clip it to a spoke. Insert the third lever a few more inches along. Take out the second lever and insert it it a few inches past the third. Work along the rim until the tire pops off.
  3. Remove the tube by pushing the valve through the hole in the rim and pulling the tube out from under the tire.
    • Remove the tube by pushing the valve through the hole in the rim and pulling the tube out from under the tire.
  4. Locate the leak by first over inflating the tire. Place the tire under water and look for bubbles to find the leak.
    • Locate the leak by first over inflating the tire.
    • Place the tire under water and look for bubbles to find the leak.
  5. Manta Driver Kit
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta Driver Kit
  6. Mark the hole with a marker, and completely deflate the tire.
    • Mark the hole with a marker, and completely deflate the tire.
  7. Select a patch kit that you will use to patch the hole. Try to pick a patch that is appropriate for the size of the hole.
    • Select a patch kit that you will use to patch the hole. Try to pick a patch that is appropriate for the size of the hole.
  8. Clean the area near the hole with soap and water, then dry it thoroughly.
    • Clean the area near the hole with soap and water, then dry it thoroughly.
    • Rough up the area around the hole with an abrasive surface such as sand paper until the area around the leak loses its shine.
  9. Apply rubber cement to an area around the hole that is bigger than the patch to ensure that the patch bonds completely.
    • Apply rubber cement to an area around the hole that is bigger than the patch to ensure that the patch bonds completely.
  10. Apply the patch to the area.
    • Apply the patch to the area.
  11. Apply pressure to the patch until the rubber cement is dry.
    • Apply pressure to the patch until the rubber cement is dry.
Заключение
To reassemble your bike, follow these directions from step 6
Brett Hartt
Участник с: 12.04.2010
116 544 Репутация
Автор 143 руководств
Команда
iFixit Участник iFixit
Community
116 членов
Автор 11 191 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 1,427
