Выберете то, что вам нужно
Wedge an opening tool between the case of the watch, and the glass screen bezel.
Pry the screen bezel away from the device.
Pull the screen protector away from the device, breaking glue sealant.
Separate the screen protector from the screen.
Insert a prying tool between the bezel ring and the e-paper screen. Move the tool around the circumference of the ring until it separates from the e-paper screen.
Инструмент, используемый на этом этапе:Tweezers$4.99
Slightly lift the screen and you will see a yellow cable that connects to the motherboard.
Use a pair of tweezers to carefully pull the cable up from the motherboard to disconnect it.
Use tweezers to disconnect the small yellow wire from the top of the e-paper screen.
The wire is connected with a bit of glue, so it will come off with ease.
Remove the three screws that hold the motherboard down using a Phillips #000 screwdriver.
Remove the cable connecting the motherboard vibration motor, microphone, and light sensor.
Remove the motherboard from the device.
Use the small plastic iFixit opening tool from to lift the battery out of the device.
8 человек успешно провели ремонт по этому руководству.
4 Комментарии к руководству
Worked great. Was able to fully remove the battery from my wife’s original dead Pebble Round. I did lose one of the tiny springs cause man those things are tiny and springy…
Great guide! Very detailed and informative. Here is a replacement battery for the Pebble Time Round:
Pebble Time Round Battery SP301618AE
It comes with all the necessary tools and carries a 1 year replacement warranty!
Battery problem 😞
I have followed each of these steps but my watch will not take a charge. It boots to a screen with a plug pointing to lightning and won’t display anything else. Have I done something wrong when reconnecting the battery or is the battery not viable?
