Выберете то, что вам нужно
Wedge an opening tool between the case of the watch, and the glass screen bezel.
Pry the screen bezel away from the device.
Pull the screen protector away from the device, breaking glue sealant.
Separate the screen protector from the screen.
Insert a prying tool between the bezel ring and the e-paper screen. Move the tool around the circumference of the ring until it separates from the e-paper screen.
Use tweezers to disconnect the small yellow wire from the top of the e-paper screen.
The wire is connected with a bit of glue, so it will come off with ease.
Remove the three screws that hold the motherboard down using a Phillips #000 screwdriver.
Remove the cable connecting the motherboard vibration motor, microphone, and light sensor.
Remove the motherboard from the device.
Еще один человек закончил это руководство.
