Pebble Time Round Motherboard Replacement
Выберете то, что вам нужно
  1. Pebble Time Round Motherboard Replacement, Glass Screen Protector: шаг 1, изображение 1 из 1
    • Wedge an opening tool between the case of the watch, and the glass screen bezel.
    • Pry the screen bezel away from the device.
    • If you have a difficult time getting the front bezel to separate from the case, try warming the watch up with a hair dryer.
    • There are three very tiny springs that are compressed between holes in the case and the front bezel. They can pop out once the bezel is removed, so don't lose them! Remove them and put them somewhere safe once the bezel is removed.
  2. Pebble Time Round Motherboard Replacement: шаг 2, изображение 1 из 1
    • Pull the screen protector away from the device, breaking glue sealant.
    • Separate the screen protector from the screen.
    • To re-seal the glass protector's glue, simply heat the glue.
  3. Pebble Time Round Motherboard Replacement, E-Paper Display: шаг 3, изображение 1 из 1
    • Insert a prying tool between the bezel ring and the e-paper screen. Move the tool around the circumference of the ring until it separates from the e-paper screen.
  4. Pebble Time Round Motherboard Replacement: шаг 4, изображение 1 из 2 Pebble Time Round Motherboard Replacement: шаг 4, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    • Slightly lift the screen and you will see a yellow cable that connects to the motherboard.
    • Use a pair of tweezers to carefully pull the cable up from the motherboard to disconnect it.
  5. Pebble Time Round Motherboard Replacement: шаг 5, изображение 1 из 1
    • Use tweezers to disconnect the small yellow wire from the top of the e-paper screen.
    • The wire is connected with a bit of glue, so it will come off with ease.
  6. Pebble Time Round Motherboard Replacement, Motherboard: шаг 6, изображение 1 из 1
    • Remove the three screws that hold the motherboard down using a Phillips #000 screwdriver.
  7. Pebble Time Round Motherboard Replacement: шаг 7, изображение 1 из 1
    • Remove the cable connecting the motherboard vibration motor, microphone, and light sensor.
    • Remove the motherboard from the device.
Заключение
Еще один человек закончил это руководство.
Christopher Ferreira
Участник с: 11/02/21
85 Репутация
1 руководство автора
Команда
UMass Dartmouth, Team 4-5, Gulbrandsen Fall 2021 Участник UMass Dartmouth, Team 4-5, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G5
4 членов
Автор 5 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 16
За всё время: 365
