Pentax Optio WP Back Casing Replacement
Выберете то, что вам нужно
  1. Pentax Optio WP Back Casing Replacement, Battery and SD Card: шаг 1, изображение 1 из 1
    • The camera used to make this manual does not contain a battery or SD card
    • Orient the camera so you are looking at the bottom and the battery compartment is on the right hand side.
  2. Pentax Optio WP Back Casing Replacement: шаг 2, изображение 1 из 2 Pentax Optio WP Back Casing Replacement: шаг 2, изображение 2 из 2
    • Unlock the battery compartment by sliding the lock switch to the unlock position (away from the arrow).
    • Firmly push the battery cover to the right and swing open.
    • The battery will be located in the larger bottom slot. Slide the plastic orange tab to remove the battery.
    • The SD card will be located in the smaller, top slot. Push the SD card directly in to hear a small clicking sound. Then pull out the SD card.
  3. Pentax Optio WP Back Casing Replacement, Back Casing: шаг 3, изображение 1 из 2 Pentax Optio WP Back Casing Replacement, Back Casing: шаг 3, изображение 2 из 2
    • With the battery cover swung open, use the spudger to remove the DC IN sticker.
    • Remove the 4.3 mm silver screw revealed.
  4. Pentax Optio WP Back Casing Replacement: шаг 4, изображение 1 из 2 Pentax Optio WP Back Casing Replacement: шаг 4, изображение 2 из 2
    • Reorient the camera so it is upright and you are looking at the back screen.
    • Remove the rubber covers in the upper and lower right side corners. Insert spudger in between the camera case and the rubber cover and push them out of their sockets. Grab the rubbers with the tweezers and set them aside. Remove both of the 4.3 mm silver screws revealed.
    • Remove the 4.3 mm silver screw in the lower left corner which resides under the sliding battery cover.
    • When removing the screw in the lower left corner, you may need to gently pry open the casing to dislodge the screw.
  5. Pentax Optio WP Back Casing Replacement: шаг 5, изображение 1 из 1
    • Locate the 5.3mm silver screw on the edge closest to the upper left corner of the LCD screen and remove it.
  6. Pentax Optio WP Back Casing Replacement: шаг 6, изображение 1 из 3 Pentax Optio WP Back Casing Replacement: шаг 6, изображение 2 из 3 Pentax Optio WP Back Casing Replacement: шаг 6, изображение 3 из 3
    • With the spudger, pry back the cover starting with the outer edge to release.
    • Lift the back cover off gently from left to right. Be cautious of the copper ribbon attached to the back buttons.
    • Detach the copper ribbon from the internals of the camera by placing a finger on top of the terminal and gently pulling on the back casing.
Заключение
Olivia Nixon
Участник с: 01/16/11
429 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 1-13, Amido Winter 2011 Участник Cal Poly, Team 1-13, Amido Winter 2011
CPSU-AMIDO-W11S1G13
5 членов
Автор 18 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 1,595
