Pentax Spotmatic Front Lens Board Removal
Выберете то, что вам нужно
  1. Pentax Spotmatic Front Lens Board Removal, Remove self timer lever: шаг 1, изображение 1 из 2 Pentax Spotmatic Front Lens Board Removal, Remove self timer lever: шаг 1, изображение 2 из 2
    • Remove cover screw using a spanner wrench.
    • Remove the self timer lever. The internal mechanism will unwind past the installed position when the lever is removed.
    • Installation Note: Temporarily place the lever on the post 90° counter-clockwise to its installed position. Wind the self timer. Remove the lever and place it in its installed position. Release the self timer.
    Спросите у FixBot
    Добавить комментарий
  2. Pentax Spotmatic Front Lens Board Removal, Remove leatherette: шаг 2, изображение 1 из 3 Pentax Spotmatic Front Lens Board Removal, Remove leatherette: шаг 2, изображение 2 из 3 Pentax Spotmatic Front Lens Board Removal, Remove leatherette: шаг 2, изображение 3 из 3
    • Apply isopropyl alcohol to the edge of the leatherette covering to soften the adhesive.
    • Use a dull scraper to get under the edge of the leatherette and begin peeling it off.
    • Fully remove the leatherette covering from both sides of the camera.
    • If the self timer lever can't be removed, the leatherette can be peeled away just enough to access the screws.
    • Installation Note: Use contact cement or shellac to reapply the leatherette.
    Спросите у FixBot
  3. Pentax Spotmatic Front Lens Board Removal, Remove front lens board: шаг 3, изображение 1 из 3 Pentax Spotmatic Front Lens Board Removal, Remove front lens board: шаг 3, изображение 2 из 3 Pentax Spotmatic Front Lens Board Removal, Remove front lens board: шаг 3, изображение 3 из 3
    • Remove four 4.6 mm flat head screws.
    • Remove one 4.3 mm flat head screws.
    • Lift off front lens board.
    • Note the position and number of shim washers at each screw location. They need to be installed in the same positions during reassembly.
    • If the top cover is still attached, lift the bottom of the lens board first. There is a lip around the top of the lens mount that engages with the top.
    Спросите у FixBot
Заключение
Sam Gustafson
Участник с: 09/01/22
14 384 Репутация
Автор 78 руководств
2 Комментарии к руководству
There is no real need to remove the top cover in advance.
Gerjan van Oosten - Ответить Поделиться
You're right. I originally included the top cover disassembly because that's the order I use for a more complete disassembly but it's not necessary to get the front cover off. And thanks for your comments elsewhere in the guides. I mention on the main camera page that the guides are for the 23102 models (the mid/late models) but it's good to have more specific notes about where they differ from early models.
Sam Gustafson - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 15
За последние 30 дней: 84
За всё время: 959
