Введение
How to remove the two flash capacitors and the PCB they are attached to. A donor part from another camera will be needed.
Выберете то, что вам нужно
Push down on the screw to depress the spring loaded hinge and release the door.
Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
Remove one 7.3 mm #00 screw.
Remove the remote trigger cover.
Remove two 5.3 mm #00 screws by the eyepiece.
Remove one 6.8 mm #00 screw in the battery compartment.
Remove one 7.0 mm #00 screw near the take up spool.
Lift the cover so it is just free of the body. It is still attached by several wires.
Use a 1kΩ-10kΩ resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
De-solder the green, blue, brown and black wires from the flash PCB.
Move the top cover to the side to access the battery connections. It is still connected by a flex cable.
De-solder the indicated joints. Use a solder sucker on the tabbed connections.
Pull the black wire from the battery flex to get more slack in the connection to the top cover.
Desolder the flex cable connecting the top plate to the camera body.
The top cover can be completely removed at this point.
Use a solder sucker to de-solder the four posts from the flex circuit.
Gently pry up the plastic carrier under the flex circuit. It may catch slightly on the battery contact tab.
This metal tab is lightly held in place with lacquer and can easily come loose. Keep an eye on it.
Remove one 3.3mm #00 screw.
Remove one 3.9 #00 screw.
De-solder the red wire.
Peel off the black tape. Leave it attached to the wires.
Gently peel the flex circuit from the surface of the capacitor.
There may be additional adhesive underneath the larger capacitor.
Lift the two capacitors and the flash PCB out as a single unit.
