Выберете то, что вам нужно
Push down on the screw to depress the spring loaded hinge and release the door.
Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
Remove one 7.3 mm #00 screw.
Remove the remote trigger cover.
Remove two 5.3 mm #00 screws by the eyepiece.
Remove one 6.8 mm #00 screw in the battery compartment.
Remove one 7.0 mm #00 screw near the take up spool.
Lift the cover so it is just free of the body. It is still attached by several wires.
De-solder the green, blue, brown and black wires from the flash PCB.
De-solder the black wire.
Pull out slack in the black wire so you can comfortably work on the underside of the top cover.
Remove one 4.3 mm #00 screw.
Be careful not to damage the feeler contacts for the metering switch throughout the repair. There are delicate and easily bent.
Remove the contact PCB.
There is a metal plate underneath that may stick to the PCB.
Remove the ball bearing from the inside of the dial.
Remove the detent spring from the top cover.
Use tweezers to release the snaps on the lock button.
Remove the lock button from the top of the dial.
Use tape to hold components in place when installing the dial.
Еще один человек закончил это руководство.
